New idea on how to transport a pickup bed
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Well, Rob (67F250CS) made arrangements for him to come today from Kentucky to pick up the '67 F250 bed from my latest parts truck. I was standing by the shop door when he arrived in a Dodge Grand Caravan....and no trailer! I'm thinking "Where the heck's his TRAILER??". As soon as he gets out, he grins and says "I'll bet you're asking yourself where the heck my trailer is!". He then proceeds to pop open the rear hatch and show me.
He went to Harbor Freight and picked up a small fold-up utility trailer like this one for $200. These things have ample load capacity and with a 4x8 dimension, is just the perfect size for transporting the bed. He simply unfolded and assembled it in the driveway in about 20 minutes. He'd mounted some 2x6's across the front and back of the trailer to hold the bed up a bit higher, and drilled holes down through them which line up with the pickup bed hold-down bolts. So after we lifted the bed off the truck chassis and set it down on the trailer, he just had to bolt it down to the bed and then drive off into the sunset. Very cool idea, Rob. I just thought you all might like to see the result....'cause it's a heck of a cool idea and a slick way to transport a bed, and when you get back home, you still have a nice little utility trailer. Here's a shot of him getting it bolted down to the trailer.
...and just for the record, Rob and I were able to lift this truck bed off the chassis by ourselves and set it on the trailer. Granted, it was HEAVY, and we wouldn't have been able to go very far, but with the trailer right next to the chassis, where we could lift if off and then just move over a few feet and set it down, the whole thing took about 20 seconds. (Well, not counting the first two times we tried to lift it off before realizing that the exhaust pipes were still bolted to the bottom of the bed....but that's a whole different story!) ;)
trukcrazy
re: New idea on how to transport a pickup bed
Post by trukcrazy »
I have looked at those trailers before and thought they would be just right for jobs like this. I am glad you posted this so we could all see how easy this tailer is to use. Especially carrying it in the back of the tow vehicle until you need it on the ground, you don't drag an empty trailer around. :thup: . John.
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
lobuck76
Post by lobuck76 »
You can haul them upside down on the bed of another truck. Put some 2x4's between and tie it down real good with a bunch of hay knots.
'71 F-100
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
I've hauled 'em upside down with stakes aligned in the stake pockets in both beds. then tie it so it don't bounce off the stakes.
Comet
Post by Comet »
I've heard of people building tear drop trailers out of those HF trailers.
That's MR. Jackass to you fellah!
67F250CS
Post by 67F250CS »
Yeah, made it home no problem. :D Thanks Keith, this is a REAL NICE bed. :D And is the correct one for my truck.
Sand and paint. :woohoo: The trailer towed fine. Nice and straight and will go 75 mph :eek: , even though the rims have the obligitory "dont go over 55 on a small peel off sticker" I just checked the hubs for overheating at every stop. They have a grease zerk on the back side.
http://aatherton06.home.insightbb.com/T ... ailer.html
Above is a link to the one that made my desicion to purchase this little gem. Fold it up and store it in a 5' 2'' space. I got it on sale for 198.00 in Nashville. Look how easy it is to store also. This is definately a useful item. The whole thing weighs about 200 lbs fully assembled. The one I got has a 1400lb capacity.
http://www.kuffelcreek.com/8'_cubby.htm
Above is the link for a teardrop trailer using one of these folding trailers.
1967 F250 Camper Special
