Disassembling a bed?
- morganater
Bumpside-smitty wants to buy my box, but we're not sure how to disconnect the passenger side of the bed. Can you just grind all the factory welds you see connecting the side? Is there a procedure for this?
1969 f100 swb ranger 460 - parting out
1968 f100 swb 429 - decking out
94 Jeep I6 Back-up vehicle
reppin' AK
reppin' AK
- morganater
re: Disassembling a bed?
No one has done this?
reppin' AK
reppin' AK
- rjewkes
Sounds like you should be able to the replacements require the old removed. why not just sell him the whole thing?
fuelly.com
fuelly.com
- 72hiboy4x4
Re: re: Disassembling a bed?
rjewkes wrote:Sounds like you should be able to the replacements require the old removed.
- hardtailjohn
I think it's all spotwelded at the factory, so in that case, youshould be able to just cut the spotwelds and free it up.... but I haven't done it, so let us know how it goes
John H.
John H.
- rjewkes
fuelly.com
fuelly.com
- Joshpow
Let us know if you get it off. Im thinking of doing nearly the same thing so please let me know if you get it off and what type of work is involved.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- mk
These boxes are built different than the newer ones. There is a seam above the side molding or spear where the lower box side is welded to the upper. The spot welds can be reached by flipping the box upside down.
Seems like a lot of work....
mike
mike
- rjewkes
I think even mine could be saved except i can get one that has been built into a trialer for 50.00 as opposed to the price for new metal.
Good luck with your project.
fuelly.com
fuelly.com
- bumpside-smitty
I looked at trying to take off the one side. First of all his is a 67 and mine is a 72 so the rear pillar also needs to be replaced. It really looks like a lot of work so after looking it over I decided that I could probably repair the dents and a little rust rather than replacing the bedside. Thanks for the input.
Smitty
Smitty
72 Ford F-100 4x4 SWB
62 Ford Fairlane Sports Coupe
71 f100 hub capper
http://www.fordification.com/galleries/ ... p?pos=-967
71 f100 hub capper
