a few more things
zakt
a few more things
Post by zakt »
Decided to cut out the 2wd power steering area that is boxed so it looks like the other side on fill the box mount holes. As I will be putting a 4x4 box up by the core support. I will although be re-boxing the frame from the front frame horns all the way to the trans crossmember later after the frame shop goes through the frame and verifies all is straight and square. I also decided to fill the holes in from the radius arm bushing mounts on the frame (took out that crossmember) as I will be putting leaf springs on. Just some clean up yet to do and more hole filling on the frame, whats the worst is grinding down the welds and getting them level with the rest of the frame. Got a jitterbug sander which helps with leveling the weld quite a bit.
Todd
1972 Ford F350 crewcab
