Progress on the 68
theskytoucher
Progress on the 68
Post by theskytoucher »
Back in March i decided to put a different cam into my 351w to try to get a little more power out of it (not that i needed it but hey i wanted it) so i took the engine out so i could change the power steering box easier and while it was out i put in the new cam!!!! I tried to get it running but i was off a tooth in the distributer so i pulled it out and low and behold the oil pump drive shaft fell and got wedged in the engine so i jacked the motor up pull the oil pan and got the shaft. I was so discusted with thie happening i went to a local machine shop to which i have ties and we drilled a hole and soildly pined the dizzy and the shaft!!!! Restabed the distrubuter and couldnt get the engine to even try to fire finally after a buddy came over we got it fired so i ajusted the rockers arms and away i went!!! But it didnt seem right it was really slugish off the line and i thought the carb was at fault so i rebuilt it and rejetted it and everything i could think of and get advice to do. Finally someone told me to remove the 2 inch carb spacer i had on it so i did and it made a huge difference, this just told me that the carb was at fault for the sluggishness off the line. Well a week went by and my Dad told me he thought he heard a miss i shrugged it off cause i couldnt hear it, another week my dad tells me he stuill hears it so i ask him how he would go about finding/ fixing the problem!!! He tells me to find a compression tester and to see if something was wrong with that so i borrowed a friend of mines tester and cylinders 1,2,3 all check out to 150 psi cool im thinking then i get to number 4 and i have zero compression, my mind starts racing to rings and all that stuff but i decide to check the rest of the cylinders first, #5 145, #6 10 psi (not a typo), #7 zero, #8 zero!!!!! So now im really thinking im in trouble but i start at the basics and reajust the rocker arms and there lies the problem at least one arm on all the previously mentioned cyl were way to tight, so i get them back to the proper ajustment and oh wat a difference a V8 running on all 8 cylinders is over a V8 running on 4!!!
Im not really sure how this happened but it did. And now as i look back the engine before i put in this came probably had a couple dead cylinders cause it didnt run at its top performance!!! So i guess the moral of the story is if you have ajustable rockers make sure they are ajusted correctly!!!! Oh and through all the messing with the carb that i did it now has 2 fuel leaks that need to be addressed but hey its all part of the learning curve right!!!
And as a side not my truck was getting 8 mpg on the 4 cylinders so i have no idea wat it will be now!!!
Well thanks for reading i had to tell someone and i figured you guys are the only ones who would listen (read)!!!
:fr: :fr: :fr: :fr:
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
wolfpack
re: Progress on the 68
Post by wolfpack »
cool i learned something from just reading.. thanks for the advice....but in it's own way wasn't it fun to learn something new even though it gets to you and now that's it's running good makes you feel good...Bo
The dumbest question in the world is the one you don't ask.
mrsnicks
Post by mrsnicks »
Yeah, I learned something too...
Stay away from adjustable rocker arms.....
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
theskytoucher
I have to say that you couldnt wipe the smile off my face when i fugured it out, :D :D I wish just i had caught it sooner than i did!!! But hide sight is 20/20!!!!
-Troy-
1976 Ford F-150 4x4
