stance...
- ezernut9mm
stance...
...this is it. it's how she's gonna sit. about two " in the front and three in the rear. i've got enough negitive camber that that's where i'm gonna stop. had to use 4* shims in the rear to get the vibration to go away.
wanting to buy a mercury tailgate!
"the man who is swimming against the stream knows the strength of it".- woodrow wilson
- customcrewcab
re: stance...
looking good
- rjewkes
so will she be making the august get together? And will she have the YOM tags? Lokkin' good man.
fuelly.com
fuelly.com
- ezernut9mm
- rjewkes
suuuuuuuuuuuuuuuuuuuuuwheeeeeeeeeeeeettt!
fuelly.com
fuelly.com
- ezernut9mm
re: stance...
just had to post another one.
okay, maybe two:
okay, maybe two:
- wt4speed#2
- rjewkes
i gotta say of the three big auto makers i would have to choose Ford and Chevyas my first two choices. mostly cuase those two trucks look like good friends.
fuelly.com
fuelly.com
- Heavenlyfire
re: stance...
That looks perfect . Nice looking ride.
- marz68
re: stance...
Wow that looks awesommmmmeeeee!
1970 F250 Camper Special
"Its no coincidence that man's best friend can't talk."
- wt4speed#2
- wt4speed#2
re: stance...
So are they dropped coils or cut? How did you drop the back?
