home made brake brakets
customcrewcab
Post by customcrewcab »
ok i didn't make them at home but at my buddys shop. i did all the machine work and design. he did the welding. not to shabby for my first ones. i'll get some more pics tomarrow of them bolted up on the spindle with the caliper mounted.
customcrewcab
re: home made brake brakets
ok i couldn't wait. heres some pic's of them mounted on the spindle. i will have to get some hardwhare to get the calipers mounted.
marz68
Post by marz68 »
That looks good! how thick is the material that you use 3/8? What calipers did you say you where using? Not bad for your first ones..
customcrewcab
more pics, ya 3/8" thick
marz68
Post by marz68 »
beefy brake setup :thup:
