front brakes upgraded
customcrewcab
Post by customcrewcab »
well i finished getting the old rotors machined today. i got the rotors turned off and then had to machine the holes for the larger wheel studs. i also had to countersink holes. i had to run 3.5 inch arp studs so i could run my 1" spacers and still have a inch of thread for the lugs. the calipers are huge and i had to run a 3" hat to clear the wheel. on the front i had to space it out 1" to clear the spindle. i am using whats left of the old rotor as a hub to hold the slide over 13" rotor. i still need to make the brackets for the calipers but am waiting for the 2" drop spindles to make sure they are the same. heres some pics
mljjones67
re: front brakes upgraded
Post by mljjones67 »
Looking good. Making progress is always nice!! :thup: :thup:
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
That's really lookin' good! :thup:
69F110
Post by 69F110 »
That is looking good! Sweet deal.
Steve Davis
Pastor and U.S. Army Retired
alvinator
Post by alvinator »
really nice looking setup :thup:
marz68
Post by marz68 »
nice job!
what brackets will you use for the calipers?
dudeman
Post by dudeman »
sweet set-up and most definetly sweet truck!
1971 F100 4x4 custom w/360 4spd
The blue bomber
http://www.myspace.com/chadleyrw <If you wish to e-mail me do it from here<
http://s173.photobucket.com/albums/w41/chadleyrw/
customcrewcab
i have to make brackets so i might draw them in autocad and have them cut, but because theres only two i prob just cut them on the bandsaw. they are nascar brakes and are bigger then the standard 6 piston wilwood calipers. the think the pistons are spread out farther then normal. they are radial mount so i just have to make a braket to go to the radial mount. the biggest thing is getting the offset out. i have these on all 4 corners so it should stop real good. hydroboost should be here this week.
looks good behind the wheel.
XLT
Post by XLT »
Your truck would be fun to cruise in. What kind of attention do you get? :clap:
XLTrucks from my town
layedout72
Post by layedout72 »
looks fun.
72truckdriver
Post by 72truckdriver »
youre truck is going to be just sick! I can't wait to see more.
customcrewcab
XLT wrote:Your truck would be fun to cruise in. What kind of attention do you get? :clap:
it got alot attention before when it was stock and lets just say i have a bunch on people stop when it was parked outside asking about it. i live off a side street and it was parks about 200 feet from the road. i started getting pissed at everyone stoping and saying you want to sell that. i always say its not out front for sale and you don't have enough money. the last straw was two work trucks pulled in loaded with works when i had my shop open. i moved it back in that day. funny thing a guy at work said he knew where i lived when i told him i had a slammed crew. i guess eveyone will know that truck when it gets on the road.
marz68
Post by marz68 »
your the man customcrewcab :thup:
I would love to own a low crew cab, maybe I should buy my dads
dent side.:twisted:
