A little closer but a long way to go
- Randle
I am just about to finish my grille. and my cab sheet metal is close. The last couple of weeks have been spent polishing my grille and making a set of inserts to replace the stock 71 inserts. Just thought I would post a quick picture to show everyone were I am trying to go sense it is not a stock look.
re: A little closer but a long way to go
omg thats gorgeous.....really. I LOVE that bumper, and the grill looks nice!
edit: love the hood without the seam
- Big D's 69
So what did you do to the bumper? It almost looks like a bumper cover. I like it. Kinda the same theme I'm going with.
1969 Ford F-100. 302 4 barrel, C4 auto, 9in 3.50 open rear, headers, power steering, Turq/wht, Under restoration. In other words, in a million pieces!!!
There is no Replacement for Displacment!!!
My Photo Gallery: http://www.fordification.com/galleries/ ... ?album=655
- 71 LONG BED
Nice and smooth, I like it! Awesome job on the body work.
John Member #1549
- lightning_msd
thats how i wanna do'er, that does look niiice. is that steel or fiberglass?
- Randle
Thanks guys, the bumper is gone, what you are seeing is the lower stock valance with a piece cut off the upper bed rail turned upside down and welded to it. The fog lights are frenched in to the bed rail. I made the grille inserts from 1/2" OD stainless steel tubing. I am thing about adding Euro Headlights and clear parking lights. On a side note the other upper bed side is now on the back of the truck as a roll pan.
- 69F110
- ExplorerNC
- Blue Cloud
- Randle
I have not done anything to the bed yet. But for anyone wanting a way to make a low cost rollpan here is one I made from the upper bed rail of a spare bed, it's not welded in to the bed now but that will come with time. You can also see in this picture I have welded and smothed the seam above the back window, and shaved the vertical part of the gutters.
man, that is slick!
- lightning_msd
nothin but slick tricks up randles sleaves, i loove it
What did you use to polish the grill? I've got a 68 with a perfect grill but badly weathered.
- Randle
I started out by using a Scotch Brite Deburriing disc on a end grinder to remove the anodized coating. Then I sanded with several different grits of paper starting at 220 and finishing up with 1000 grit. Then finished polishing the aluminum with a 8" loose section buff mounted on a 1/2" drill, and Autosol (a polish I got from Eastwood). I started trying to use White rouge and Jewelers rouge but found out that Autosol will polish it a lot quicker. But the main thing is alot of time and elbow grease.
- ICEMAN6166
that is very nice work.
http://fordtruk.com/forums/album.php?ca ... user_id=26
you can ford a river or stream and get to the other side, if you dodge it you will not, and if you drive a chevy to the levee it will run dry and the music will die.
