Body swap to a 4x4
Re: Body swap to a 4x4
My f150 has a c6 automatic with 400 in it. The f250 has automatic (I assume c6) and 390 in it.
Welcome to the site, there's a lot of info here.
The post you responded to has 3 pages of conversation that should answer your questions.
If you have a more specific question , feel free to post it in one of the above categories.
I don't know what frame perches a 400 takes so hard to say what you will need to bolt in the 400 in place of the 390. They are 2 different engine family's and you'll probley have to change a lot to make a 400 work. Would be a lot simpler to find a different 390 to put in the truck.
- HIO Silver
Otherwise than the high/low hump issue the body is a straight swap.77Ranger wrote:I don't mean to butt in but but I have a 77 f150 2wd. I have come across a 76 f250 4x4 truck with no bed,shot cab, bad motor, good trans good transfer case. Can I just put my body and motor on the 250 frame to have 4x4?
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
