70 Custom--It's HOME
- 69F110
- 67mann
re: 70 Custom--The Fun Begins (Updated 6/9)
My bedside panels are just about complete---finishing touches will wait until entire truck is ready for paint
So this week I'll concentrate(on yard work & the pool-or I'm gonna be unemployed and homeless
- AlleyCat
Looking good.
Get it done while you can 'cause you get back to work your " project efficiency" is gonna go straight down the toilet.
Clay
72 F100 4x2 Custom,289, C4 " Slow Ride "
70 F250 4x2 Ranger XLT , 360, C6 "B52 - IV"
96 F150 4x2 XL, 300, E4OD, daily driver
" Professional Wrecker Operators - We Pull for America "
- convincor
Did you buy or make that roll pan??
68 Custom Cab Shorty, 390, C6, 9"-3.50:1 Currie T/L
"Still Plays With Trucks"
http://s101.photobucket.com/albums/m41/convincor/F100/
- 67mann
Re: re: 70 Custom--The Fun Begins (Updated 6/9)
Bought it off a member in here and I think he said he bought it out of BOTPconvincor wrote:Did you buy or make that roll pan??
http://www.blueovaltruckparts.com/s-87- ... ?PageNum=0
- 67mann
re: 70 Custom--The Fun Begins (Updated 6/21)
Used Herculiner--two heavy coats after fixing and priming. Here's the tailgate together again
So I'm going at the cab next--got most of the sheetmetal to fix it(bonus when I bought my parts truck)
As you'll see in the next pic's---she needs alot of TLC
Engine and drivetrain are on hold until $$ income is back to normal
- FLATBEDFORD
You sure have some work to do on that. I guess my truck is in pretty god shape for a NY truck. Looking good.
Steve
1970 F350 DRW Factory 9' Platform/Stake, 360, T18.
Passed on to new care taker July, 2013
My Photo Gallery
http://s115.photobucket.com/albums/n298/flatbedford/
My Photo Gallery
- 67mann
re: 70 Custom--The Fun Begins (Updated 6/24--Cab switch)
This wasn't the route I was gonna go,but it's gonna save alot of time and
trouble for me. I need to do some research on what problem I may encounter.
I know the dash won't be right,but what other problems will I face?
- SteveC
make sure you use the pedals from the 70 the brake switch from the 67 pedals is different. I dont think the heater boxes are different just the controls
thats all i can think of as of now
I don't really care about brands Chevy Ford Dodge ...as long as it doesn't sound like two old dudes farting in a coffee can.
http://s169.photobucket.com/albums/u223/imabaka70/ Projects listed on the left side
WOOOT!! i passed my mechanics classes. Now working as a mechanic and waiting to go for my ASE certifications.
1967 f-100 4x4
1969/72 f100 351w EFI m5r2 5 speed
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- 67mann
- SteveC
i think so but im not sure. The gas tanks mount differentlly and use a different size on gas line that screws into the tank
and not sure but might be a good idea to use the wiring harness out of the 70 cause the ignition switch is different in 67 and so is the brake light its
and of course a lot of cosmetic things are different
But also the radio is a smaller size....i found that out when i was gonna put a small am fm out of a vw into my 67
1967 f-100 4x4
1967 f-100 4x4
- 67mann
The 67 cab is stripped down and today I got to do some work on it.
Starting with lower door corner repair
Had to patch inner panel and redo floor rail
Slowly but surely fitting floor pan
Before I can though---need to patch in part of the seam(firewall)rail and get cab corner laid out.
- 67mann
re: 70 Custom--The Fun Begins (Updated 7/7Cab patches)
Floor pan fitted
Gas filler hole patched
Got the other side cut out ready to fit floor pan and the cab corners are getting bead blasted and rust trteated before they go back on. Some other patches need to be takin care of---speaker holes and misc. screw holes.Then I can flip it on its back and address the bottom cab support.
- kaptnkaos
Hey 67mann...
Nice work... I like the gas filler hole patch.
I wanna fill mine in as well, but, I dunno know how ta weld...
KaptnKA
S
KaptnKA
