Not Much to be Jealous of Duane, The wife isn't too impressed with me at the moment! She Keeps Mumbling something about more Junk in the Yard! Anyway, Made a little progress today, and got a solid Plan in the making for both trucks;duaneo wrote:What an exciting project! I'm a little jealous!
Cheers,
Duane
The F-350: Parts for Bluebeast, and eventually a 6BT Cummins, but not until the Beast is finished.
Pic of both trucks for Posterity:
Let The Teardown Begin!
The first Clue as to how long this truck has sat (besides the Rancid Gas in the Tank), is the amount of Wasp paper I'm finding in Everything! every Panel removed, reveals at least one nest!
grill Removed:
LH Fender:
Still had the Factory Rubber Shields behind the fenders, and the Push clips didn't break when I removed them! (Can't say that about the shields though)
The Bottoms of the "A" Pillars, and the cowl look Awesome! And I only Broke 1 Bolt off removing the Sheet Metal (Bottom of RH Fender)
soaked the bolts for the Inner Fenders/Radiator Support with PB Blaster. Going to let them soak overnight, as I've still got to remove the Wiring. I Lube the bolts with WD-40 just prior to removing them.
