67 short bed
Re: 67 short bed
nice truck
Re: 67 short bed
I just love me some Iron
- 67mann
Re: 67 short bed
451 cubic inch side oiler
220 miles on a local Bars and rods cruise
Performed flawlessly
- popeyes71
Re: 67 short bed
-Popeye-
1971 F-250 4x4 Highboy
Re: 67 short bed
what size wheels and tires? thanks
Re: 67 short bed
if shes not loping shes not running71fordkid wrote:Holy crap yeah it is.BobbyFord wrote:That's a lot of camshaft
Re: 67 short bed
May have to try out the new to me Drag Mag wheels
Re: 67 short bed
Enjoying your thread. I think I remember you mentioning in another topic that your exhaust turns down just before the rear axle. I am considering doing the same and wondered if you have had any issues or problems with this arrangement, and how do you like it overall? If it isn't too much trouble, I would appreciate seeing a picture of the exhaust as well.
Re: 67 short bed
There is a video of the truck in the video section of this sight with the turndowns on a gravel road .Lowell wrote:Enjoying your thread. I think I remember you mentioning in another topic that your exhaust turns down just before the rear axle. I am considering doing the same and wondered if you have had any issues or problems with this arrangement, and how do you like it overall? If it isn't too much trouble, I would appreciate seeing a picture of the exhaust as well.
At least the dust is behind me
I currently have 3 inch exhaust on the truck .
It has a slight flattening of the pipe for the trans crossmember
other than that the pipe is perfectly straight
The mufflers at mounted at a slight angle for drive shaft clearance and to tuck them up under the bed
The turn downs are mounted so the exhaust hits the ground where the tire meets the road
