I really like this build thread you have going here.
Also, I really like your wheels....
Any info that you are willing to provide on them? Brand (manufacturer/supplier), offsets, pcd?
Looking forward in your feedback.
Keep up the progress on the truck
JG F100 wrote:well I didn't get to do as much on the rear as I had planned. I'm using an explorer rear and wanted to do a four-link but ended up using the leafs for now. I did get a shorter driveshaft and since the 8.8 uses a flange got that one too. I was able to reuse the ubolts and explorer shock mounts if I rotated them. The angle is a little off but it seems to work even with the old shocks. There isnt much room between the axle and frame, may notch it later. I still need to set the pinion angle and weld on the spring perches.
cleaned up and brushed on some rustoleum then sprayed some undercoating on the bed
I should have matching wheels soon, need to get some tires...
thats it for now.
