Forest Service Truck Coyote Swap
Re: Forest Service Truck Coyote Swap
Thanks Paul
Finished inner kick plate and welded in. Finished lower rocker repair and then applied epoxy primer to the area. These lower corner repairs eat up some time!!
Started to fab up floor repair panel.
Nice work, you are going to have a great truck shortly!
- Fordkid68
Very nice work!!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
My first truck,
^^Build Thread^^
I got lower corner fitted and welded in and new lower door post patch panel. I still have the corner to finish where the door seal goes, but I decided thats enough for today- its nice out!
Time to enjoy my finished project.
- Fordkid68
Hell yeah!! That is a sweet FJ! You really do beautiful work!
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
miller wrote:I got lower corner fitted and welded in and new lower door post patch panel. I still have the corner to finish where the door seal goes, but I decided thats enough for today- its nice out!
Wow is all I can say. You do some amazing metal work sir!
Thanks guys! I fitted passenger floor repair and welded in.
I bought this new tool. I have alway wanted one for some reason. It was a total impulse buy from craigslist.(similar to this truck!) The guy had just listed it and had several people coming to look at it the following day, but he lived just a few miles from my house so went that night and picked it up. Used it tonight to form some metal. 122 pounder from England late 1800's is what the guy said, but who knows. Its well used!
The passenger side upper seam had some holes so before I install the cab mount I cut out those pieces and started fabricating some new ones.
- Fordkid68
Awesome work as always! At least you didn't have to replace the whole passenger floor pan.
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
Yeah it saved me a few bucks, but I think took as much work as the driver pan! I finished the passenger upper floor to firewall seam. I still have a bunch of grinding to do everywhere.
Fuel tank showed up damaged. I guess it will be a couple more months on that. I thought about trying to straighten it out but that Taiwan metal will probable crack.
Well that stinks. Have you tried to check for leaks?
