started my tank swap
Re: started my tank swap
Get better soon
back finally feels better, got the mounting done. made straps, still need to clean and paint and put the rubber isolators in. wound up with 16" of ground clearance. i welded the nuts to the inside of the x members. also mounted the mustang fuel filter bracket / filter
** not sure why the tank looks lop sided, must be the angle of the picture
- Fordkid68
Sweet! Glad to hear your back is getting better. Keep up the good work!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
My first truck,
^^Build Thread^^
Looking good!
Still blows my mind, (I've "preached" the Bronco tank install for years) why anyone could/would even fathom putting the Mustang tank in that requires butchering up the flat portion of the rear bed area, (which also makes hauling anything 8' long a thing of the past).
i completely agree. i hate the filler in the bed floor. i guess if the truck is only a hot rod or a show truck it would work, but not if your going to use it.basketcase0302 wrote:Looking good!
no updates, i've been working almost every day. i'll post more progress when i get a chance to get back to it.
This is another project on my list. I definitely dont like the fuel nozzle in the bed floor. I really like the bed rail ones but not sure if I want to do that but we will see when its time. Looking good on the project.
I've been following this. I like this much more than the mustang tank . Have you figured out how to get the sending unit to work? I'm doing this also just ordered the tank and pump assembly .
Not real sure but isn't the Bronco tank sending unit the same ohm resistance?="M-100"I've been following this. I like this much more than the mustang tank . Have you figured out how to get the sending unit to work? I'm doing this also just ordered the tank and pump assembly .
still working a bunch of ot, but i got a few pics to show how the tank fits installed. there is a little more than 15" of ground clearance. i still have to cut in the fuel door.
- Terry Veiga
That looks good and seems like a relatively simple install. Any idea how low it hangs compared to a typical Mustang tank retrofit?
TERRY : 1972 F100 Ranger XLT SWB
2WD, 429/C6, A/C, P/S, P/Disc
In His Holy Name
In His Holy Name
no idea, but i know the mustang tank is much flatter.Terry Veiga wrote:That looks good and seems like a relatively simple install. Any idea how low it hangs compared to a typical Mustang tank retrofit?
