mockup, before installing
soooo im gonna use the left one. the right 3M seems over zealous.
some more mocking
sooo this distributor doesn't fit. it hits my heater hose fitting.
so i got a different one a pro bullet
buuuut this one hits my temp sensor
i also went ahead and put a new water pump on, it was lookin and sounding ruff. and painted a few things on the engine.
i also took off the exhaust manifolds, and cleaned up the block a touch.
i got my twin i beam w/disk brakes from a guy a few towns over.
he took it off a 74 f100 for me and brought it to my house for $240. which included the drag-link and proportioning valve. not a bad deal i say.
soo he said the proportioning valve was in good working order when he pulled it. the fluid coming out of it was clean.
but should i rebuild it anyway??
oh and one of the twin i beams has a slight vertical bend..... not sure if im too happy about this.
what do u all think the verdict is on the severity of such a bend?? do i need to get another?
oh and heres my front sway bar
ok on too some booster moch up questions
so heres a booster i got off a 67 fairlane. works great, but i need to know if anyone thinks the hood wont clear it?
i used the 67 fairlane brackets and all.
here are some pics for u
if it does clear the hood, which i think it will. it will require only 2 modifications to fit perfect.
right here i will have too lengthen a bolt whole on the brackets to make the bolts fit.
and right here, where i will have to lengthen the rod to fit just right
today i painted a few things(mid paint, not a good time to take a pic)
and cleaned fire wall up with a scraper and a sos pad&water. then painted it once dried.
ill paint the rest later. ive got some rust fixing/preventing work to do before i paint the rest.
