bumps with lowered altitude!! (lots of great custom bumps!!)
Re: bumps with lowered altitude!! (lots of great custom bumps!!)
I have a 69 F-100 and I'm about to start a crown Vic swap. I'm looking at going with a set of 20in mobsteel wheels. Can anyone give info on there custom wheels as far as back spacing and tire sizes?? I plan on doing on axle flip in the rear and keeping the 5x5.5 pattern since they offer that pattern. Any help would be great!
Reason: added picture
That it?
Pictures probably work the same just use the button that says “Img” above the posting window to wrap the tags around your image URL.
HaHaaa!!!! Thanks DuckRyder.....
I am just getting ready to start on my 1967 Ford F250 long bed. I have been doing a lot of research regarding lowering this truck but few companies have kits available for the F250. Lots of companies have kits for the F100 trucks, so I was wondering if those F100 kits would work on my F250.
Hey marz what suspension is under you truck as of now? I know in the beginning you said MII but I was curious if you changed anything to make it lay the rockers.
Put some DJM Beams on my 69 F250 C/S with a set of Chevy C20.coil springs cut 1.5 coils off
also a 6" rear flip kit with C notch pretty basic kit Although I had the 7/8 king pin so the beams are F100 and they fit right .You do not have the required permissions to view the files attached to this post.
