68 f100 restoration.
Fordkid68
Re: 68 f100 restoration.
Post by Fordkid68 »
Thanks!
I never even thought about it being for a camper. But it very well could have been because it did have a sliding rear window.
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
Fordkid68
Post by Fordkid68 »
Got the holes around the back window ground down. you can barely tell there were holes there!
Also did some grinding on the passenger side door jam that I had to replace.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
and then I started tearing the vent windows apart.
Adam
My first truck,
^^Build Thread^^
You are making good progress.
Fordkid68
Post by Fordkid68 »
Thanks! I'm trying.
Adam
My first truck,
^^Build Thread^^
flyboy2610
Post by flyboy2610 »
Looking good! :thup: :thup:
Red Green
you'd better be right.
Fordkid68
Post by Fordkid68 »
I finally got the rear crossmember out. Someone had welded the top lip to the underneath of the frame rail where it was almost impossible to get to. But I was able to get a small air grinder back far enough to cut most of the way through it, and then just wiggled it back and forth and hammered on it till the rest of the weld finally popped!
And I have no clue why anyone would weld there because all the rivets were tight so it wasn't loose, and it was only welded on one side!
I also stripped more paint off the cab floor to get ready to paint the floor and the firewall.
Then I moved on to welding up the fuel filler hole in the cab, since I am going to put a mustang tank in the back.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Here is the fuel filler all welded up. It didn't really come out super great, but I guess with a little putty it will work.
And, some treasures came from Summit racing! Since nobody makes headers specifically for a Bump351 Windsors in a Bump. I got these that are made to fit a 302. Hopefully they will work. There nothing fancy, just Summit brand, but they were the cheapest ones I could find so I figured I'd take a chance and see if they will work.
I also got a new 70 Mustang gas tank. I will be working on getting it in pretty soon.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
I went to the Summit racing store yesterday, and found some treasures on the sale rack where they have all of the open box, and returned items.
I found a 28oz flywheel that will work on my Windsor, and a K&N air filter. Both for half price!
And today I went to a local junkyard and looked at suspension. It's from an 03 Mercury Grand Marquis, And looks to be in pretty decent shape, and for a good price. I will be picking it up within the next few days!
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Happy Easter everybody!!
Adam
My first truck,
^^Build Thread^^
jzjames
Post by jzjames »
:thup: Happy Easter.
New parts are always fun!
Fordkid68
Post by Fordkid68 »
hfdco4 wrote: Thu Apr 21, 2022 1:53 pm New parts are always fun!
Absolutely!!
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
I just got back from the spring Carlisle swap meet, and it was really nice out today, so I decided to get some primer sprayed in the cab
The hardest part was masking everything off!
Taped up all the holes in the firewall to prevent any overspray.
Then I got ready to paint!
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
I mixed some paint thinner with rust oleum rusty metal primer, and sprayed it with a Harbor freight spray gun, and it actually turned out pretty good!
I tried to get as much as I could shot up underneath the dash, but it was kinda hard to spray up there. Mybe i'll go and cover some more of the underneath with a rattle can if I need to.
It even tuck to the bottom side of the roof, and didn't even drip!!
Adam
My first truck,
^^Build Thread^^
