Coolant (?) leak inside cab
Inside the cab...appearance, repair, upgrades
bph
Post by bph »
Hi all. 1970 Ford F250 camper special here.
A couple weeks ago I noticed some liquid streaming down on the interior, passenger side from right under the dash below the glove box where air duct runs for the ventilation system. I figure that there were some gaps around cables passing through the engine/firewall so I sealed up any opening that I could find in the engine bay.
Today much more fluid leaked out while driving and I noticed that it is viscous, sticky and kind of green in color....radiator fluid?? I do see what looks like a hose running from the rear of the radiator through the firewall. Any idea what would be leaking right behind/below the dashboard glove box?
Gaslight
Re: Coolant (?) leak inside cab
Post by Gaslight »
Chances are that is a failing heater core. It could still be a hose leaking into the interior. But really its going to be a failing heater core. You will need to remove the heater system from under the dash and put in a new heater core.
Jake
1969 F100 Ranger
390FE1972
Post by 390FE1972 »
Here are a few threads that have good information in them about the heaters, there are also some Youtube videos that show people replacing their heater cores on these trucks. Hope this helps :D
http://www.fordification.com/forum/view ... hp?t=82940
viewtopic.php?f=6&t=73960&st=0&sk=t&sd=a
http://www.fordification.com/forum/view ... hp?t=44760
