power steering pump pulley
- jimmy828
Adding power steering and looking for parts. I'm trying to locate a pump pulley stamped 6AA (C7AZ-3A733-E) I have the crank pulley (C8AE-6312-D) that is suppose to work with pump pulley # that is listed in this post, at least that is what my research tells me. Thanks
Re: power steering pump pulley
Old Skool here, (the dark side member parts monkey might be able to help you with finding the specific part number-I'd always argued the point with him that part numbers are mostly worthless to me as there is so...many of them that will interchange YET HAVE A DIFF PART NUMBER)."jimmy828"Adding power steering and looking for parts. I'm trying to locate a pump pulley stamped 6AA (C7AZ-3A733-E) I have the crank pulley (C8AE-6312-D) that is suppose to work with pump pulley # that is listed in this post, at least that is what my research tells me. Thanks
YOU'RE LOOKING FOR THE PULLEY THAT IS PRESSED ONTO THE PUMP CORRECT-OR THE WATER PUMP PS PULLEY?
WHAT ENGINE?
IF YOUR LOOKING FOR THE PUMP PULLEY YOU'RE PROB GONNA WANT TO CONSIDER A NEW ONE AS MANY ARE TRASHED WHEN THEY ARE PRESSED OFF OF THE OLD PUMPS. Try Green Sales or RedHead for a new one.
http://www.greensalescompany.com/
https://redheadsteeringgears.com/
- jimmy828
by my research, there is 3 different PS pulleys that will work with the crank pully that i have. PS pulleys are stamped 6AA, AC, AG. It has to be pressed on. I'm not running AC. I'll be running belt straight from crank to PS, not going over water pump. Hope this makes since.
- 67mann
I will try to look today when I'm out in the shop.... replaced mine with billet pully
just have to find the right container
- 67mann
If your interested Pm me .... it's yours for the cost of the ride
- jimmy828
I'm late getting back on site. Just saying thanks for the offer but i have a pulley laying around that is shaped like that but was not enough offset to it. was going to have to use to many spacers on bracket to make it work. After posting about pulley, i found one that would work (8SA)with less spacers.67mann wrote:Can't find any #'s on it but, I know I only had one PS pump(plus it was sitting on top of my crank pully)that I worked with.
- 67mann
