72 f250 4x4 old blue
Re: 72 f250 4x4 old blue
New brakes, backer plates painted, wheel bearings, e-brake cables, etc.
1972 f250 4x4 390 4speed
Nice progress, are you quarantined at home? I am working from home at least three days a week. I have had some extra time but not enough!
I'm LE so I have not stopped working, little jealous of those with too much time on thier hands but happy to keep a stable job when so many others found themselves unemployed.
Thank you for your duty sir. I truely appreciate my situation and the ability to work at home.
Love it! Keep up the great work!
Haven't got much done recently but a little progress was made.
Still doing good work I see. Little progress, is still progress!
Great metal work!
Any updates on Old Blue?
Starting to put drivetrain together.
Spraying firewall and hopefully the floor this weekend.You do not have the required permissions to view the files attached to this post.
Great to see you back at it!
Got epoxy primer and a coat of high build on the cab. I did the interior in hot rod flat baby blue to see if I liked it.
Good work, making progress is so great.
Cab is done. I'm no painter but happy with how it turned out. Good enough for who its for.
Got doors stripped, have to do inner and outer door skins
