Hi. I have a 1970 F100. I am wondering what would cause the voltage at the hot-when-on lugs in the fuse panel to be less than 12 volts. I have 12.6 at the battery and 10.2 at those lugs. This is with the truck off. I had an HEI dizzy wired to one of the lugs, it had 12 volts when I installed the dizzy last August. Now, just this week it won't start, and I only have the 10 volts at those lugs. Any suggestions on where to start looking?
Thanks!
Voltage drop
Re: Voltage drop
Remove the fuse block and check the connections on the back. Those often get corroded. Also wrap some steel wool around a screwdriver tip and scrub the the fuse contact points.
Re: Voltage drop
Thank you! I will definitely do all that!sargentrs wrote:Remove the fuse block and check the connections on the back. Those often get corroded. Also wrap some steel wool around a screwdriver tip and scrub the the fuse contact points.
- sparky72
Re: Voltage drop
Goes without saying to unplug the battery negative before you go rooting around in the fuse panel with a screwdriver and steel wool
Taylor
1972 F250 Ranger XLT 2wd / 8100 GVW / 390 / T18 / 3.73 D60
Re: Voltage drop
I had kinda figured as much, but thanks for the concern!sparky72 wrote:Goes without saying to unplug the battery negative before you go rooting around in the fuse panel with a screwdriver and steel wool
