Shortening bed with seam at the front edge
WhitsEnd
Post by WhitsEnd »
I've seen multiple threads that seem to be copying each other and cutting beds down right in the middle of the panel.
Has anyone ever sectioned a bump bed in a way that puts the weld at the front edge of the box?
I think it could be done with nearly zero body filler and no need to weld across the middle of the floor.
8) 1970 F100 Ranger 2WD
:thup: project link: http://www.fordification.com/forum/view ... 22&t=83642
Re: Shortening bed with seam at the front edge
That sounds like the way to do it , in my opinion.
With some careful measuring and cutting near the front of the box, you'd have very little mud work.
I'd use a flange tool and overlap 1/4 inch instead of trying to butt weld all that.
If you're making a true shortbox you have to lose 4 inches in the rear also.
WhitsEnd
Post by WhitsEnd »
cep62 wrote: If you're making a true shortbox you have to lose 4 inches in the rear also.
Yep, not interested in a true shortbox, and only thinking about removing 13" from the front so there will be equal bed forward and aft the wheel well. I call it a medium bed.
corner27
Post by corner27 »
A little late response, but I came across these guys who have done a few bed conversions. I think they use the technique you are talking about.
http://www.rodsnrestos.ca/69ford/
