Hi there.
First of all, Im a Fordification-member from Sweden so please excuse my spelling and English...
I have a Ford F-250 1970. Every now and then when I try to start the truck it won't start, completely dead. Ive checked the start engine and that one is working. If I move the gear shift back and forth a couple of times it often "solves" the problem... So my question is, could it be the ignition switch or the ignition cylinder?
Question from a dumb swede...
Re: Question from a dumb swede...
Welcome. I'll assume the truck has an automatic transmission? If so then the neutral safety switch needs adjusted. It mounts to the top of the steering column under the dash and will have two wires for the reverse lamps and two for the starting circuit. Just loosen the two mounting bolts and slide it to the desired position. Your truck should start in 'park' and 'neutral'.JohanNB wrote:Hi there.
Good luck.
Neutral start switch, no doubt. Five minute fix.
or, money.
or, money.
Mr JohanNB, to the best site period.
Hope you like it here.
Pull up a chair and stay awhile.
Thanks a lot, it worked!!
from Georgia! It's right here.
Thank you so much for the help!!! It worked!
- colnago
Guaranteed, your English is better that my Swedish!JohanNB wrote:First of all, Im a Fordification-member from Sweden so please excuse my spelling and English...
Joseph
"Sugar", my 1967 Ford F250 2WD Camper Special, 352FE, Ford iron "T" Intake with 1405 Edelbrock, Duraspark II Ignition, C6 transmission, front disc brake conversion.
- hot-rod
@ JohanNB from Germany
@colnago; after 4 or 5 moonshine your Swedish will be perfect I have tested it myself
