Spark Plug Wires 8mm
fordd
Post by fordd »
Hello
Somebody here use spark plug wires 8mm moroso, taylor,magnecor ? good brands?
thanks
Ranchero50
Re: Spark Plug Wires 8mm
Post by Ranchero50 »
I ran FMS ones before they were FRPP and you can't go wrong with Autolite wires. I'd avoid Accell and the other seem expensive for your needs
HIO Silver
Post by HIO Silver »
I use Pertronix wires. Works great and appears period correct.
sargentrs
Post by sargentrs »
I bought Moroso 8mm peformance for my Fairlane and they work great with very high quality.
Manny
Post by Manny »
Have a set of taylors on the red bronco that are great. For all the rest of the time i am very guilty of running the for 9mm wires. :thup:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Jacksdad
Post by Jacksdad »
I've used Accel Superstock 8mm wires for years on any vehicle that runs a Supercoil. I learned my lesson when I fried a store bought HT lead late one night, finding one end completely charred. At the very least, I run one as the king lead from the coil to the distributor as it gets hit with every spark.
But that said, my bump was getting harder to start, so I investigated and found this...
To be fair, it's been on the truck for a good few years and is ungodly long because I relocated the coil to the fender. It's been fine since I trimmed it and put a new terminal on it.
