69Ford wrote:There are two types of cap's vented and unvented. If you use the unvented cap on a unvented fuel system it will create a vacuum in your fuel tank causing your engine to strive for fuel as it is fighting for fuel against the vacuum. This can be very hard to diagnose. Sometimes with a full tank that was filled with cold gas on a hot day can cause a pressurized condition in the tank forcing gas out of a vented cap. Especially if that cap already has fuel against it. As parking the truck on a slant drivers side lower. I'm not a 100% sure but think the early bumps had an unvented fuel system requiring a vented cap later bumps have a vented fuel system no need for vented cap.
I am fairly certain the '71's and newer had the venting system, but I can't be absolutely certain. I really need to look and see if my tank has it or not, I've just been being lazy. But, because I'm not sure, I have been pretty good about popping the cap off every time I open the door to get in the truck to normalize the pressure in the tank "just in case". I don't typically drive it long distances, either. Today was a rare exception where I went 30 miles to work because I have an appointment to get a quote on rebuilding the engine after work and they wanted to see it (I think they might think the engine is already out of the truck, so this could be interesting).
And now the paint under my cap is a big mess. Apparently the PO was aware of this potential issue and never allowed it to happen because the truck hasn't been painted since the '80's and that area was fine prior to my screw up.
