I have a 1972 F250 4x4. It sat for about 7 years and the drivers side door handle / latch mechanism is very sticky. If I open the door from the outside and close it the latch works fine. When I open the door from the inside the latch does not 'reset' and the door will not stay closed. I have the door panel off, and I can reach inside behind the interior handle and reset the mechanism manually, then the door will latch.
I'm looking at LMC Trucks catalog and they list a part called Door Handle Release (16). Is this what I need to replace? My truck currently has the handle inside armrest type door handle (13). I used to have a 68 F250 that had the longer arm pull handles(11). LMC lists those as available as well.
If I buy the replacement Door Handle Release, will the older style door handle work with it? I really prefer them.
Also, the only key I have for this truck only works in the ignition. Do you think it would make more sense to replace the locks on the doors, or to get a locksmith to re-key them / make me a key for them? Annnndddd (sorry for all the questions) my truck has the toolbox on the side of the bed. I have no key for it. Has anyone had a new lock put in / had it re-keyed?
Thanks in advance.
Ryan
