Hood bracing 1967 F100
- travlinjohn
I have a 1967 Ford Step side that the bracing for the hood isn't fastened across the center. The fit is still good but when closing it flexes and you can see the bracing separating from where it makes contact. What kind of adhesive is used the make the bracing stable?
"Laugh Hard, Hang Tough, Lend a Hand"
- BobbyFord
Re: Hood bracing 1967 F100
3M seam seal should do the trick. Stay away from the water soluble stuff.
- HIO Silver
Tape it off for a nice crisp edge before applying 3M seam sealer
Consider using 3M window weld.. comes in a caulk gun tube and would be neater than brush-on stuff if that is what ya end up with. Pretend yer caulking a bathtub.
Btw, I've got the same issue with my 71 F250. For now, I leave it be.
70 F100 LB 2WD, 360FE, E-Street EFI, TKO-500, 76K original miles.. follow my rebuild: The Lo-Buck Bumpside
71 F250 LB, 2WD, 360FE, T18, PS, PB, D60 with 4.11s
73 F100 SB 4WD, 390FE, NP435, +4 on 35s
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- travlinjohn
Thanks guys. It's good to know that help is just a post away.
