Side molding rivet removal Questions
jay_m16a2
Post by jay_m16a2 »
Couple of questions.
1) Is there a special tool or process to remove side molding rivets?
2) Do you use same size rivets (new) when you install them or do you have to use a slightly larger size?
Bronco_77
Re: Side molding rivet removal Questions
Post by Bronco_77 »
All u need is a drill bit that is the same size as the rivet and drill them out. Some might try to spin on u but if ur careful u can reuse the clips if there not brittle.
68 f100 390 3 speed on the collom G maw gave to me G paw drove in late 70s till late 80s
77 bronco 302 lifted 5.5 with 33s and rears cut
69 Mustang boss 302 clone bought when was 14 sold when was 28 to build house
jay_m16a2
Post by jay_m16a2 »
Thank You!!!!!!
flyboy2610
Post by flyboy2610 »
LMC Truck sells those clips if some of yours break. This link will take you to page 94 of their catalog, but they have some on page 93 as well.
http://www.lmctruck.com/icatalog/fb/full.aspx?Page=94
48prerunner
Post by 48prerunner »
I just used a step bit till it took the head of the rivet off then just pushed the rest of the rivet out with a center punch.
