Painting the truck tomorrow, have a questiom
windhamdw
Post by windhamdw »
What does everyone use to wipe down the truck with before painting it to make sure it's all clean. So far I have washed it and wiped it down with lacquer thinner.
windhamdw
Re: Painting the truck tomorrow, have a questiom
Post by windhamdw »
Also forgot someone told me I could just use windix glass cleaner.
jimmy828
Post by jimmy828 »
Lacquer thinner leaves a film but the film can be removed with denatured alcohol. Use them both.
DieselS10
Post by DieselS10 »
Wax and grease remover is best IMO.
hazelnut
Post by hazelnut »
DieselS10 wrote:Wax and grease remover is best IMO.
X2
Lacquer thinner is a little harsh, a good wax and grease remover is best.
Windex will work if it's all you have.
use good clean paper towels ,wipe it on a small area ,then wipe it off when it's still wet with a dry paper towel.
windhamdw
Post by windhamdw »
Thanks everyone, I will give it a try.
Mach428
Post by Mach428 »
It's probably too late for this paint job but I've always used a product called final klean. Available at automotive paint supply stores.
hazelnut
Post by hazelnut »
Also wipe the truck with a tack rag to remove any dust or small rash that will show up in the paint.
SmokeyBear
Post by SmokeyBear »
Careful with the lacquer thinner, depending on what primer or sealer you used, it could soften it and will leave fisheyes. I use reducer to wipe down then two tack cloths.
70 F-100 XLT
"Christine" Gone but not forgotten.
72 F-100 Ranger XLT
mikhett
Post by mikhett »
prep solvent is all I ever use.
