Windshield Trim
Windshield Trim
My truck has the weather stripping with the groove in it for trim around the windshield. I realize this trim is hard to come by but I've found a a couple of trucks that have it and was wondering how hard it is to remove and reuse. I would like to put it on mine.
My goal in life is to be as good a person as my dog already thinks I am!
1968 F-100 Longbed 390/C6
Re: Windshield Trim
It's not to hard to remove, When you start pulling the trim you need to roll the trim in towards the windshield to remove it.
There's a write up with pictures on site somewhere if you look around.
Re: Windshield Trim
The windshield trim can be pulled off with your fingertips. I have successfully removed trim many times this way. You might have to feel around for an area that is proud of the rubber then start there. Try the bottom corners.
66 F250 camper special
69 F250 Explorer
85 Mustang GT with 1900 original miles
92 Festiva with 538,000 original miles
86 E350 extended WB van
Various IH & JD tractors (5)
TT & XT500 mc's (6)
BSA, Triumph's and twenty Yamaha two strokes
69 F250 Explorer
TT & XT500 mc's (6)
Re: Windshield Trim
Thanks guys
- tnab1970
Re: Windshield Trim
Very easy to remove. I use two medium "pinch bars" one down on the glass crown up and the second on top just under the edge of the trim. THe drip rail trim can be removed this way as well, be patient don't get in a hurry.
Re: Windshield Trim
I've heard the trim on 73's would work too?
