Does anyone know where I can buy a set of quality one piece wheel housings for my bed?
I bought a set from lmc and I'm not impressed the stamping is crappy and they are two pieces welded together
Source for bed wheel housings
Re: Source for bed wheel housings
I bought some from Dennis carpenter, I haven't put them on yet but will put it up to the wheel well to see how it will fit and let you know.
Can you confirm if they are one stamping or two separate stamping a welded together? I bought a set from Dennis carpenter but they ended up being for a bronco and the dimensions were slightly smaller.
Sorry for the delay, life got in the way
I just put the molding up to the wheel well and it look fine to me. It's a one piece stamping.
The part number is C7TZ-9929164-A
Hope that helps.
Hope that helps.
I think what the OP is looking for are the wheel housing (some refer to them as wheel tubs) not the molding that goes around the wheel well opening. Here is the link to the PN listed from DC for the molding:
http://dennis-carpenter.com/trk67-79whe ... gs/c/1394/
The wheel well housings are listed here:
http://dennis-carpenter.com/quarter-pan ... 9727700-A/
I didn't read the original post right did I
At least everybody now knows the DC wheel trim fits like it should.
