1970 F250 4X4 Rebuild / Updating
- moonhanger007
Re: 1970 F250 4X4 Rebuild / Updating
love the frame "rotissere"!
It can be either Yankee Ingenuity or just plain Cheap Solution. Needed something quick and didn't want to brake the bank.
My next job is cleaning the rear springs and hangers. I picked up some distilled water, washing soda, container, wiring and have a battery charger. I am going to de-rust using electrolysis. I will take pictures once I get set-up some and cooking the parts.
So I through my front axle u-bolt brackets in the Electrolysis Bath and they came out quite clean. Just some wire brushing. I let them dry and brought them to work and blasted them quick, they are ready for primer now. I need to work on the rear springs and get them set so I can verify the spring hanger location and how many degree spacers are needed.
Started relocating the rear axle spring hangers. When I changed out the front hanger it has pulled the axle forward. This causes the driveshaft to not fit. So I have the get the placement set so I can get the spring hangers mounted so I know what holes can be welded up and what I need to drill. Should have pictures tomorrow.
managed to grab the same pic twice.
I am still working the proper location for the rear axle and drive shaft travel.
Well I had time on Sunday to work on the truck and finalize the rear axle location. Once I was able to get the full slip/travel out of the slip joint things went much better. Now I have to mark the hole and drill them. Next is to drop the transfer case so I can rotate the frame and start fixing the cross members.
Well got the rear spring brackets in their finally location. So I started removing the drive shafts. Found the front one frozen at the slip joint. The rear is dented, so now I need two drive shafts and I have had zero luck finding any. Does anyone have a front and rear drive shafts they want to part with?
I went through my extra parts and located 2 rear drive shafts and one extra center drive shaft, so that issue is handled. I did get the front slip joint to move but it is junk do to rust, have to get it rebuilt. I was also able to remove the transfer case and rotate the frame and drill all the holes for the rear spring shackles.
Here is the rebuilt bracket.
Rebuilt the rotted bracket above.
Getting small things done. I have decided that I am going to use a 1988 Chevy Suburban 31 Gallon gas tank.
Made a Chevy Suburban Fuel Tank mock-up out of cardboard to see how it would fit. After talking to a couple of guys who are doing the same conversion with the 25 Gallon Plastic tank it would appear to be a good fit. They measured the outside dims as 26" x 26" x 11" and the 31 Gallon tank is 2" deeper at 13". The only issue is the sending unit has to be modified to use a Ford rheostat.
Got to go to the Junkyard this past weekend. Found a Blazer that had the tank still in it but the yard had put a hole in it to remove the gas. I was able to get good measurements and locate a skid plate to remove another day. I did get a rebuilt alternator out of a 96 Taurus, it is the 130amp one with the wiring for $26. Hope to go back tomorrow and get the skip plate and the sending unit out of the blazer. I will just buy a brand new 31 gallon tank online.
