You are going to laugh at me....the pads were some auto parts store pads that I put on the white truck when I built it before the Wilwoods went on there. Then they kicked around my shed for a year or so then went on this truck. So to say I have a better setup now is an understatement.
I ordered in a new power steering pulley last night and it somehow showed up this morning at Oreiley's....,.,I never buy anything there but they said they could get it there in the morning and they actually did that. It was the right one to boot.
While I was at my normal parts store visiting my buddy Andrew, I asked about a proper pulley installation tool and looked around on his shelf of tools and low and behold there was a whole kit that had the 8x1.25 one in it that I needed. So I got my crap and headed on my way. I used my Garage heater (Hair Drier and a Towel) to heat up the pulley. You would not believe how hot it will get things, hotter than it should.
The pulley installer was key, and I think was my problem all along (Hopefully) It has a bolt that threads into the pump, then a thrust washer, a bearing and then the threaded rod and press portion. It takes all the rotational torque out of the equation. Got it all ready and with the hot ass pulley, I tossed it on there, got the tool installed and pressed on the new pulley, there was no drama like the first time, no washers getting stacked up. I guess you live and learn.
The pulley went on at least 1/4" or more further than the last one. I am pretty sure that was causing some alignment issues. That combined with a much higher quality belt, I never new that Gates made a regular 6 groove and a green label six groove belt, there is a difference in the backing, the depth of the grooves and the thickness of the belt as well. Still learning.
Got the belt routed and installed and fired it up with no drama. Also finally installed the covers on the battery while I had that disconnected, looks more finished now than before.
Also got some brake ducts installed, not happy with them at all but they should work for the weekend no problem.
So a trip around the block filled up with fuel and onto the trailer.
First time towing with the camper, the hitch extension and the trailer, truck did remarably well considering that there was a massive headwind all the way out here.
Arrived without issue, got the truck unloaded and the registration done, chatted with a few others that were here and spending some quality time with the wife in the camper.
All in all a great day...we are pretty tired though
![Image](http://i1133.photobucket.com/albums/m588/hackster1/Coyote%20F100/20160319_183955_zpsga1qktdv.jpg)
