Here's my Ford OEM, (part# D5TA 28238 CIA 0249) 79' power brake front disc with rear drum proportioning valve from my 79' E-350 4 X 4 I parted out. It has always been stored inside bagged and sealed. All the threads in the ports are excellent and this valve has no issues-brakes were working fine when the van was parted out due to rust. I started cleaning it up to put front discs on the F-350 but never got that far. It still has the two metal spacers where I removed it from the frame rail as well as the original rubber cap over the spool end. My loss is your gain here as you won't find too many of these in good working order as this one is, (and there is a "rebuild kit" available for this still if need be). Shipping will be a small flat rate USPS box which gives us both a tracking number, (insurance will be extra-I believe it's $3.80-but not sure) and I can use other shipping methods as well if you prefer. I have to get $45.00 for this part please-no low ballers-I'm a Veteran living on disability. There is a schematic here on Fortification that shows the proper plumbing or piping on this. I still have many...obsolete parts for bumps so please ask if you need something.
P.S. Don't forget to tip your waitress, (I mean thank you Kieth / Robert / Jamie / moderators) for keeping it real...and alive here)!
