The Good:
For a 47 Year old truck, it drives pretty good, No Rattles, Just basic tinkering to make all the lights work, a new Carb (Someone tried to adjust the old Motorcraft with a BFH), and new U-Joints/Center Bearing. The windows are not scratched, the interior just needs some minor touch-ups to be great, and The AC does work, though it is weak. The doors require very little effort to open, and close, as I've had to remind the Mrs. not to slam them.
The Bad: The Fuel Gauge works when it wants to, The clutch, even though it locks down, has been slipped to the point that it chatters violently when taking off.
The Brakes work as well as Manual Drum Brakes are going to, Pulling the Drums revealed new shoes, and wheel Cylinders all around. I found 2 front Cyl. Kits in what's left of the glove box (which might explain why the right side of the Grille/Radiator Support has been pushed back 1"). The Front end will need to be re-bushed,so I think the Starting point of the Project will be to upgrade the Steering/Brakes/Tires.
Now to Start Obtaining Goodies to stick on her!
Pete
