Anyone need an F-350 front axle. 67 to 72
I hate to scrap this front axle. I was hoping someone on here could use it. It is out of a one ton truck that a buddy of mine scraped about 10 years ago and I saved the axle because it was good. Looks like a 4.09 ratio. The numbers on the gears are, 10-4-67 DANA 18520 M8R84 45-11 The rear would most likely have been 4.10's as the front axle must pull a little faster. It is a DANA 44 and is the early closed ball and drum type with Warn locking hubs. Still has the front springs, a piece of the frame, and steering box attached. It is located in Craryville NY. my number is (518) 325-7610, Ask for Dave. Just make an offer. Thanks.
Re: Anyone need an F-350 front axle. 67 to 72
Here's a photo. Also, I have a backhoe and can load it for you. Dave!
- Manny
A complete one will call ya.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
If I don't answer just leave a message and I'll get back to you. I'm in and out this time of the year. Thanks, Dave!
That's no BS there!
""Never shoot a large caliber man with a small caliber bullet."
2017 Ford Raptor
1948 Willys CJ2A w/ Ford Flathead V-8
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
