Will the rear brake hose from a '75 highboy work in a '68 Bronco Graveyard sells the '75 but not the '68.
Steve.
High boy rear brake hose?
- eggman918
Steve
The"Filthy Beast"- '68 F-250 Crew Cab 131"W/B 4x4 4BT compounds hx30/Wh1c,5x.012" sac injectors/ZF 5/NP203-205 /3.54 44 trutrack front/60 trutrack rear on 33's. 2nd owner
"Beauty is only skin deep....Ugly is to the bone"
It is more important to understand what you don't know than what you do know,because then you can start to learn..???
"you must deal with the attaboys and the ass chewing s with your head up and looking them in the eyes" T.J.E. aka My Dad
There are only three types of people wolves, sheepdogs, and sheep. What are you?
Re: High boy rear brake hose?
Hey eggman,
According to the Raybestos website, the hose for the Bronco is 15.5" long versus the highboy which is 24 5/16" long. The threads should be the same at both ends. The only thing that might be a problem is the bolt hole in the 't' end of the hose. I don't know if it will be the same size. You should be able to get both hoses at an auto parts store to compare.
Mark
Mark
- eggman918
Yes I am needing to replace the hose on my '68 and the length is my biggest concern.I ordered one from Bronco Graveyard,I am tired of the blank stare I get at the auto parts store
when I tell them I need parts for a '68 Hard to find a skilled counter person here
thank's for the input Steve.
Steve
- BobbyFord
Check out Dorman Products...> http://www.dormanproducts.com/c-172-brake-hose.aspx
Just input your vehicle info at the top left for the part number, any auto parts store should carry or be able to get it.
- eggman918
Thanx Bobby The magic code to bypass the terminal operators apathy
Steve.
Steve.
Steve
