greenhiboy wrote:Hi Ryan,
Great looking truck! I just bought a 76 F250 4x4 and want to put a flatbed on it. Is there anything you would change about your flatbed design? What year mustang tank did you use? Is it the 16 gallon or 20 gallon version? Where did you mount the filler? Have you noticed it being any stiffer off-road? I read that the frame is very flexy. Did the flatbed take any of that away? Keep us posted on how it does at Rubicon!
Mark
Thanks!
Flatbed's are cool, mine paid off today (pictures below). Good question, not sure if i would change anything. Hmm. There are things i am still going to add, but i don't know about changing anything. I guess i planned it out decently
There has got to be something that i could of done better
Mustang gas tank is a 1970 20 gallon. Filler is mounted in the rear C channel piece of the flatbed. Check out this thread:
http://fordification.com/forum/viewtopi ... 6&start=45
Haven't noticed it being any stiffer. After adding the headache rack and boards, it has to be about the same weight as a stock bed by now. Highboy frames are indeed very flexy. I've taken my highboy on some trails when the stock bed was on and it really shows the frame flex. PIctures area couple pages back in this thread. I'm not sure if the flatbed took any of it away, haven't wheeled with it on yet. I don't expect it to take much of it away though, the .120 metal structure probably flexes with the frame and the frame will still flex pretty good between the flatbed mounting and the cab mounting.
I've decided it won't be going no the rubicon because i've come to realize how bad things are about to get with me going to college and paying $20 to commute every day. Lifting it how i wanted to (4") with 35's for the rubicon would take away more mileage, i can't afford to do that right now. I'm going to get 33's and a 2" lift for it instead.
But, i am still going to take it up to Strawberry pass, which is a very cool trail, not the rubicon but it has some tricky stuff that should be great in the highboy... i'll have pictures this summer of that.
Installed an autometer 2 5/8" sport-comp 0-73ohm fuel gauge today! First time ever having a bump with a fuel gauge!!! It is so cool!!!!!
And depressing.
I drove it for 10 minutes and the needle dropped quite a ways. IT's too big of a sweep, it lets me see how fast i'm burning gas too well
No more running out of gas on the side of the road! (it was a once a month type thing!)
Then i worked the highboy for the first time
Towing 8,000 pounds
