If I remember correctly, I received my floor pans and cab mounts within a week.basketcase0302 wrote:How quickly is the shipping from BOTP? I've never ordered from them before, just wondering...
67 Project Update 6/1/2023 (Multiple New Posts With Pictures)
- JWW
Re: My 67 Project-Floor pan install 2/21/10
Thanks for the positive feedback guys.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
2004 F150 Crew Cab
- JWW
Re: My 67 Project-Cab Mounts 3/24/10
Well, I received some an exciting picture this evening. My cab mounts and cab support pieces are installed.
Also, I will be picking up a freshly sandblasted frame tomorrow. I will post some before and after pictures of that.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- stephen44
Looks Great - I am at the same point ...
What are your plans for the cab corners - you can get the outer ones but not the inner ones and they are not flat so not so easy to make up yourself with out a beader ?
Stephen
Stephen
thanks
Stephen
(1967 F100, FE352, 2wd, 3 on the tree, flareside)
Stephen
- JWW
Thanks!stephen44 wrote:Looks Great - I am at the same point ...
Stephen
I have the cab corners. They go on next. A friend is doing the welding work. He does a heck of a job.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- stephen44
i'm assuming you have the outer corners - but what about the inner corners - they are two different parts and you can't buy inner corners ? - the corners are a sandwich - outer and inner
- Stephen
- Stephen
thanks
Stephen
Stephen
- JWW
I agree about the inner cab corner pieces. May look at fabricating something.stephen44 wrote:i'm assuming you have the outer corners - but what about the inner corners - they are two different parts and you can't buy inner corners ? - the corners are a sandwich - outer and inner
- Stephen
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- trukcrazy
Great job. It is good to see these projects coming back around.
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
- JWW
Thanks TC. I'm sticking with it, just have to save a little $$ at a time so that I can work on her.trukcrazy wrote:Great job. It is good to see these projects coming back around.
My plan today is to apply "Chassis Saver"
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- JWW
Re: My 67 Project-Painted Frame 8/18
Well, I finally got my frame painted. I did three coats of the Chassis Saver. Then I applied two coats of low gloss paint from Tractory Supply. Here is the top coat I used:
Here is a pic of the sandblasted frame:
Here is a pic of the finished frame:
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- Caseys71
Casey
16 years old with a 40 year old truck (well almost)
1971 F-100302, T-18 4 speed, 3:55 rear, & an Edelbrock sticker on the ashtray.
"Don't worry about what you become, just make sure that you're successful at what you do."- Mr. English
"Value what you DO have over that which you don't."- Forrestbump
"Wanting can sometimes be better than having, never stop dreaming... it's what keeps us all going."- Forrestbump
1984 Toyota 4x4: 22-R, 5-speed, 3" suspension lift, 35's and 5:29's
- 67mann
keep that frame covered if you take outside The UV's will dull that Chasssis saver
- JWW
Thanks. Actually I went ahead and topcoated the chassis saver. I didn't want the black to become dull. As far as wearing the chassis saver, boy it takes a while to get it off. Thank goodness I only got a little on my arm and elbow.67mann wrote:![]()
Your catching up and eveythings lookin great
How long ya been wearing the chassis saver
that stuff doesn't come off for nothin
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- FormerMarine1981
Looks great man, Keep up the good work. If you still have the engine stands from the 75 frame you might be able to sell them, they looked like they were small block stands
What we do in Life, Echoes in Eternity
- stephen44
Nice !
- Stephen
- Stephen
thanks
Stephen
Stephen
- 67mann
