found the complete serial number. F25AEA59504 There is a star in front and behind the serial #.
So it looks like a have a F250. I now am going to check out past post to find out how to figure out the rest.
Mine also has the stars before and after the VIN that is on the rail.
Using Keith's VIN decoder, it looks like you have:
F25 - F250
A - 6 cyl, 240
E - Made in Mawah, NJ
A59504 - Serial number, indicates it was made in Dec 1966, thus a 67 model
Steve
1971 Ford F-250 4x4 Highboy - Pics 2003 Toyota Tacoma 4x4
In life many men take the path of righteousness, some take the path many others follow (G.M. owners, for example), some take a more arduous path, some a simpler path. I, sir, took the PSYCO-PATH!!
IIRC, The "ODDBALL" F100 CS/SCS also have an 8 Lug pattern as they have the 3/4 Ton Suspension. And the flexomatic.
fuelly.com
Thanx keith that is why I'm not the only person here. must of been a 250 with a 100's hood on it.I seen in the junkyard happens all the time out here they have a 250/350 and slap a 100/150 hood on em just cuz they fit.
fuelly.com
Go up to the top of the page and click on the 1967 by the VIN Data...it will help you decipher the entire VIN and then some.
I spent 1/2 hour going thru old post, then found it up on the top! DUH! I knew I seen it somewhere.
Thanks guys, I am going to look into the build sheet.
heres an example of a truck's build sheet (just happens to be mine)
