390FE (406ci) for #50, built by Tom Lucas at FE Specialties.
Moderator: Ranchero50
Re: 390FE (406ci) for #50, built by Tom Lucas at FE Specialties.
Wow, here I was staring at the two bottom pictures saying 'nope, nothing different between them...
Good to see you are using your bed as a catch-all.
For the cables You can get a one hole loop thingy and use it as a tie back, run it to one of the engine mount bolts to keep the starter wiring where you want it.
Jamie
Jamie
Is the engine hoist gone?
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- 1971ford
Look to the left of the picturesDoug Comer wrote:Is the engine hoist gone?![]()
Doug
Or if you are looking for a difference in the last two pictures, the difference was suppose to be in the third to last picture (truck pointing into garage) and the last two pictures, truck pointing outside)
I didn't even think about the possibility that it was moved under it's own power... ooooooooo
-Ryan
Thank Gawd I wasn't the only one...
- robroy
Good day Ryan, Robert, Joe, Jamie, and Doug, thanks for your marvelous replies!
First I must apologize for supplying a hint and then failing to follow up with the complete story in a timely fashion! Also, I now realize that by using three photos instead of two, my hint was quite ambiguous--thanks for humoring me!
So yesterday afternoon, Kasie helped me roll #50 out of its cave in to the direct sunlight. She sat in the cab and helped me to test the brakes by applying varying pedal pressures while I pushed; the brakes seemed to work perfectly fine!
The engine area really lit up in the sunlight!
Having the choke linkage attached and working nicely made the first start relatively easy!
More for the sake of documentation than entertainment, here's a video of the The Yellow Jacket starting for the first time (since being installed in #50)! I have other videos that I'm working on encoding and will post later today--those do a better job of showing the engine running once it had fully "woken up" from its long slumber.
It probably would have started more quickly if I'd primed the carburetor with gas and done better with the choke control, but I was very happy nonetheless!
As y'all know, the H.264 video has the best quality yet only works with very up-to-date computers, while the WMV video works almost everywhere!
H.264 (10MB) WMV (14MB)
Ryan, Robert, Joe, Jamie, and Doug, thanks for your fantastic replies, and y'all can expect more entertaining videos later on today!
Robroy
Excellent, thanks Ryan!1971ford wrote:SOoo exciteddd![]()
Yes it is; it is extremely nice. If only there were more of a private drive to legally test the truck out with, it would be my dream Bumpside project area! Yet even with things as they are now, I couldn't ask for anything nicer.1971ford wrote:It must be 100 times nicer working with fresh air and a driveway worth of space now! Not to mention the light and everything else as well.
Absolutely CORRECT!DuckRyder wrote:You turned it around ?![]()
Under its own power?
I was highly tempted to do this, yet all the wires were too loose and floppy, and the battery wasn't being held down by anything but gravity. And the driveway to this house is a steep hill!fomocoguy wrote:If it's moving under it's own power, I would almost bet he drove it around the block. I know I would have...![]()
Yes! Sorry for being so ambiguous with the wording of my challenge. I actually wasn't planning on putting in that funny challenge, so it wasn't planned out all that well!Ranchero50 wrote:Wow, here I was staring at the two bottom pictures saying 'nope, nothing different between them...
HA! Yes it's truly marvelous to have a giant storage bin attached to one's project car, isn't it! I'll clear it all out pretty soon here, in preparation for taking it out on the open road!Ranchero50 wrote:Good to see you are using your bed as a catch-all.
That is a great idea Jamie, thanks for suggesting that! I think you're probably on to something there. I'm not sure if that will help me with the problem area that's right next to the starter though, but I will spend some time staring at it with your idea in mind!Ranchero50 wrote:For the cables You can get a one hole loop thingy and use it as a tie back, run it to one of the engine mount bolts to keep the starter wiring where you want it.
It's still there Doug, although it could be hidden from view! (But that's a great observation!)Doug Comer wrote:Is the engine hoist gone?![]()
You got it Ryan!1971ford wrote:Look to the left of the pictures![]()
Precisely! Thanks for being such a good sport by rolling with my ambiguous challenge!1971ford wrote:Or if you are looking for a difference in the last two pictures, the difference was suppose to be in the third to last picture (truck pointing into garage) and the last two pictures, truck pointing outside)
Yes that it did!1971ford wrote:I didn't even think about the possibility that it was moved under it's own power... ooooooooo
You did a great job Jamie--it was an unfair challenge!Ranchero50 wrote:Thank Gawd I wasn't the only one...
Robroy
- robroy
Good afternoon!
This video's a continuation of the First Start video. You can see how sensitive this engine is to the gas pedal! The video also shows the oil pressure and how it responds to RPM. It seems to be in the 75 to 80 PSI range.
H.264 (9MB) WMV (7MB)
Stay tuned for more!
Robroy
Robroy
- fomocoguy
Sounds great!! I like the poo eatin' grin on your face every time you rev it up a little...
Congrats on all your hard work! It's very nice when it pays off in the end for sure
Joe
1971 F100 flareside 8ft
1964 Chrysler New Yorker Town and Country wagon
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- robroy
Good afternoon Joe and Mike, thanks for your excellent replies!
I'm sure it will sound significantly different once it has some real pipes between the headers and mufflers--that's what I'm really looking forward to hearing!
In this video Kasie's at the wheel, experiencing the insane energy of The Yellow Jacket. She was a little shy of the gas pedal, and I don't blame her! This video also includes walk-around footage of the engine bay.
H.264 (29MB) WMV (22MB)
Joe and Mike, thanks for your great replies!
Robroy
Thanks Joe! That was a funny expression on my face huh! This is the first time I've had anything to do with an engine like this, so its throttle response made quite an impression on me.fomocoguy wrote:Sounds great!! I like the poo eatin' grin on your face every time you rev it up a little...![]()
Sure is, and this time it looks like it's working out!fomocoguy wrote:Congrats on all your hard work! It's very nice when it pays off in the end for sure![]()
Thanks very much Mike!mljjones67 wrote:Awesome. Good work robroy
Robroy
- robroy
Good afternoon,
Here's a concise video showing The Yellow Jacket starting, idling, revving, and being shut down.
H.264 (3MB) WMV (4MB)
Thanks for watching!
Robroy
Robroy
- HayHauler
There's nothing like firing up an engine for the first time
it makes all the time and money spent seem finally worth it.
congrats Robroy!
now the fun begins!
congrats Robroy!
No problem can withstand the assault of sustained thinking. -- Voltaire
- robroy
Good afternoon HayHauler, thanks for your excellent reply!
In this video, The Yellow Jacket reanimates #50. This is the first time #50 moved under its own power in perhaps eight years!
It was too short of a drive for me to make very many observations, and the wood blocks I was using for a seat made it a little awkward. Yet here are my notes:
HayHauler, thanks again for your great reply!!!
Robroy
Indeed!HayHauler wrote:There's nothing like firing up an engine for the first time![]()
Very true, and thanks!!!HayHauler wrote:it makes all the time and money spent seem finally worth it.
congrats Robroy!![]()
now the fun begins!
- The engine has quite a SOUND to it when you're in the cab. I'm actually surprised by how powerful its sound is, since it has a pretty mild camshaft in it! The sound is truly exciting--it's a whole new type of animal.
- The steering worked, and actually felt a lot easier than I remember it being years ago.
- I had to get used to the clutch, especially with the wood blocks I was sitting on rocking around under me. But the clutch felt surprisingly smooth and pleasant to use! It also felt quite intuitive and forgiving, kind of like the clutch in a modern vehicle only very heavy.
- If I remember correctly, I actually used zero or nearly zero throttle the whole time! This engine is perky to say the least, and in such close quarters, I didn't want to try it out (and risk smashing in to the house)!
- I used only granny and reverse. I wasn't ready to try out 2nd gear in such close quarters, with such an eager engine!
- The brakes worked surprisingly well for their state. The rear brakes need to be bled pretty bad, and probably rebuilt also. They're also adjusted very poorly. But they worked!
- Thanks to Mustang Steve's ball bearing pedal support upgrade, the clutch and brake pedals felt amazingly smooth and precise. What a difference from my worn out original setup!
Robroy
- robroy
'Afternoon!
Here's the final video taken yesterday afternoon, of The Yellow Jacket running briefly in the garage.
H.264 (1MB) WMV (2MB)
Thanks very much for watching and for all the excellent comments!
Robroy
Robroy
- 70_F100
Robroy, that's SAWEEEEEEEEEEEEEEEEEEEEEEEEEETTTTTTTTTTTTTTTTTTT!!!!!!!!!!!!!!!!!!
Sorry I haven't commented, but I've been working feverishly on my C6 to T19 swap.
Look for some updates from me in a couple of days, with things I NEVER expected.
It's one of those things that, "Well, I'm doing this, and I found this, so I might as well fix this while I'm at it, and those other things need to be done too, so..............."
Wise men talk because they have something to say; fools talk because they have to say something.--Plato
Why is it that there's seldom time to fix it right the first time, but there's always time to fix it right the second time???
That's not an oil leak
That's SWEAT from all that HORSEPOWER!!
- sport71
Robroy great progress. Your doing a supurb job with all the details,
and I know the rest of the build will be no exeption.
Those who do not learn the lessons of history, are doomed to repeat it.
