Have 72 F350 2wd will that steering box work for 4x4 and crossover steering?
Todd
72 F350 2wd steering box for 4x4?
- zakt
1972 Ford F350 crewcab
- Wes
Re: 72 F350 2wd steering box for 4x4?
What are you asking ? You have one, you want to know if a 2by will work for cross over ?
Wes
http://www.fordification.com/galleries/ ... ?cat=10402
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
no i dont think so. the 4x4 mounts infront of the axle and the 4x2 mounts behind the axle.
- Wes
A 2 by box can be used if remounted in front of the axle, w/ drag link to driver side knuckle not cross over
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- averagef250
It can be used for crossover or knuckle steering mounted up front, but I'd toss it and get a 78-79 box or run the highboy box with power assist. The 2wd boxes are not very good under a 4x4. They stick up too high and interfere with the radiator.
- fomocoguy
I don't mean to hijack but are there any modifications needed to mount a 78-79 box out of a bronco? I found one locally and may buy it if it's an easy swap.averagef250 wrote:It can be used for crossover or knuckle steering mounted up front, but I'd toss it and get a 78-79 box or run the highboy box with power assist. The 2wd boxes are not very good under a 4x4. They stick up too high and interfere with the radiator.
- Wes
Yep you need to swap out the rack for a 2by box, to change direction the box turns. link to Fordification info http://www.fordification.com/powersteering4wd.htm. I did it on my 67 high boy my thread http://www.fordification.com/forum/view ... =9&t=15700.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
Since you're going crossover, why not use a GM Saginaw box?
-Lance
-Lance
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..
