1969 F250 4x4 Highboy 7/9 rubicon
re: 69 F100 Ranger project-6/25,more stripping and LOTS of P
And where did the dog get black on her paws??? The good news is that my garage floor won't rust.
- 1971ford
Re: re: 69 F100 Ranger project-6/25,more stripping and LOTS
1971ford'sdad wrote:And where did the dog get black on her paws??? The good news is that my garage floor won't rust.
she probably stepped poop. since theres no mud. if it was por-15 then it would still be on the carpet.
your garage's concrete is as rust free as can be
-Ryan
- 1971ford
- 71Ford100
Ryan are you going to give it another coat from a paint gun?
Lance Peters
'72 250 4x4 project,''71 F-100 daily driver,69 F-250 4x4 Crew, '68 F-100, '68 F-250 crew under restoration, '52 Dodge 1/2 ton overload, gazillion tractors and combines
- 72stepside
You should try spraying it on the underside of your bed before I try it
I'm not interested in brushing that much of it on.
Chris
72 F100 Stepside w/ 78 300 CID
Hedman Headers
Disc Brakes
Power Steering with 3 STILL on the tree
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Loooong way to go on this one!
Hedman Headers
Disc Brakes
- 71Ford100
My other question is to anyone Ryan and I have debated over Por's warning label about even getting a drop of water in the can will ruin it (haven't read the label myself). Can anyone solve our mystery as to why this would be?
Lance Peters
- convincor
POR cures with humidity. The lower the humidity is in the air the longer it takes to cure. A drop of water in the can is like adding catalyst to epoxy.71Ford100 wrote:My other question is to anyone Ryan and I have debated over Por's warning label about even getting a drop of water in the can will ruin it (haven't read the label myself). Can anyone solve our mystery as to why this would be?
from there web site-
"HOW LONG DOES IT TAKE POR-15 TO DRY?
That depends on the ambient humidity (surrounding area). The more humid the area, the faster the dry time."
68 Custom Cab Shorty, 390, C6, 9"-3.50:1 Currie T/L
"Still Plays With Trucks"
http://s101.photobucket.com/albums/m41/convincor/F100/
- 72stepside
Continuing hijack...
I painted the rest of the rear frame on my F250 last Saturday. The humidity had to have been in the 90% range. The paint was setting up in the brush and the small pan I was painting from. Back in the spring, I didn't have that problem.
Chris
Hedman Headers
Disc Brakes
Hedman Headers
Disc Brakes
- 1971ford
it says that it will not stick properly if this happens71Ford100 wrote:My other question is to anyone Ryan and I have debated over Por's warning label about even getting a drop of water in the can will ruin it (haven't read the label myself). Can anyone solve our mystery as to why this would be?
-Ryan
- 1971ford
UPDAaaaTeE:
-removed the undertank stuff from the 71 to use in the 69. since it will be a tow vehicle i dont want to stop alot at gas stations with a big trailer. removing this damn setup took about 4 hours. what a PAIN. its still not even all removed, im still grinding off rivets of brackets.
-stripped top/bottom and POR-15'd dual tank skid plate
-stripped/POR-15'd all the brackets besides the ones that are still riveted onto the 71
-stripped front/back and POR-15'd core support.
-POR-15'd the insides of the doors
-went shopping at Harbor Freight, got 4 wire wheels, cut off grinder, disks for it, PB blaster a air line fitting, satin black spray paint
-sliced the under-bed spare tire mount off. it was stripped.
-stripped the bottom of the lower valance
-spare tire carrier
-disassembled a leaf pack
-stripped all the leafs out of one pack
thats all i can think of.
WOW. i found rust holes! the only rust holes on the truck, i was absolutely amazed
note to self: do NOT paint brackets on top of newspaper. newspaper tends to stick to por-15, ruining the endges of the bracket resulting in poor results. i just scraped the little bits off and ill give them another coat
inside doors
next is going to be stripping the other half of the bed
-spare tire carrier
inside doors
-Ryan
- 72stepside
re: 69 F100 Ranger project- 7/13 more stripping/ por-15
I hang the small stuff up. I stretch a ratchet strap between two posts in my shop and hang the part to be painted off the strap with clothes hanger wire. If you're careful, the POR-15 will stick to a tiny bit of the hanger wire, which is much easier to deal with than newspaper.
Did you decide if you were gonna spray the underside of your bed? Try it out and let me know how it goes.
Good progress !
Good progress !
Chris
Hedman Headers
Disc Brakes
Hedman Headers
Disc Brakes
- 1971ford
im going to use coat hanger for now on with small stuff, i like the ratchet strap idea too.
im not going to be spraying any por-15, since i dont that much more to do, ill just keep brushing. i dont want to risk my spray gun.
im sure it would look good, i know once im brushing it on the bottom of the bed its going to be dry by the time i get to the other side. ill have to hurry.or maybe do a half at at time.
-Ryan
