I've done that a couple times. Found out that the thinkness of the gasket was the problem. They need to be the very thin type. My Subaru uses the same one exept it is thick. Now you know how I broke mine.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
1980 Built Toyota "Trail Rig". My last 1971 "Highboy" pics
fuelly.com
fuelly.com
fuelly.com
Aw, you could just pop on down to WallyWorld and get a tube of Thermostat housing glue and she'll be good as new.
And dont forget to get some liquid bolt shrinker. I am sure the bolts have strectched a bit.
I can laugh only because I dun it too. Threw out the paper one and replaced with a homemade cork one. I had a roll of the stuff left over. Its 4 times as thick as paper and no leaky. Yet.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
I figured out why my mechanical temp gauge was reading 140 degrees. I pulled the housing off and found the t-stat sitting sideways. Yes, it was still intact. Turns out that there are three different sizes of t-stat housings. I had the wrong housing. I checked out two chrome housings and they both were the wrong size. I had to hunt the boneyards until I found one that fit the t-stat and the radiator hose.
For my 460 I used the housing off a Ford diesel engine. It fit just right and was pointed the right way. Now I have a blue engine with a gray water neck. Function before fashion.
Greg
