I recall a thread awhile back regarding proper jacking points on our trucks. Someone, I think, said that it was harmful to use the twin I-Beams. I usually use either one to raise one side and the frame cross member to raise the whole front end. I use the axle housing or differential on the back. So my question is: Do others use the I-Beams and if not, why not? Thanks.
Here's a photo of the way I do it.
jor
Jack Stands Placement
- jor
re: Jack Stands Placement
I was one of the people who originally asked the question. Since then I've come across this instruction sticker for using the stock jack.
I would rather use the frame, however. Just seems more secure, I guess.
- Hawkrod
The original jacking instructions were meant for lifting a single tire only. If you are lifting the whole front end then you should not use the I beams due to the risk of slippage caused by the I beam angle changing while lifting. Also once the vehicle is lifted the I beams should not be considered a safe jack stand location as any weight shift of the truck can also change the I beam angles and cause slippage and potential disaster. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
http://www.supermotors.org/registry/veh ... 9&detail=1
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- jor
Thanks to you both. When I lift the whole front end I use jack stands on both I-beams and the leave the floor jack engaged with just a little bit of pressure if I can. If I need to work in that area I just have the jack stands. Now that I think about it I guess you are exactly right about the slippage so where is the best place to put the jack stands if not the I-beams?
jor
jor
- boots
I have used the i-beams before
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Hawkrod
You can lift on an I beam but you should not support on one. As I already noted, it isn't safe. The strength of the beam is not the issue. The issue is the fact that the beam changes angles when load is applied to the vehicle. For example, if you are under the truck and unbolt and lower the trans the suspension will lift the truck slightly. Because the I beams are only moving on the outer end and pivoting on the inner end they travel in an arc. When weight is removed and the front end lifts it can be enough to allow the stand to tip. This is a Darwinian issue to be truthfull, some people need to learn physics from first hand experience while others are content to plod along listening to common sense and avoiding potentially dangerous situations that would otherwise not provide any benefit. As far as what any of you have done, it really has no bearing on safety, for example a lot of people have climbed under cars being held up by bumper jacks, in fact it still happens all the time, but unlike the lemmings, I am not inclined to do it just because somebody else does, Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- flyboy2610
I NEVER get under a vehicle supported by jack stands on a suspenion component. I place my stands on the frame rails, just behind the firewall.
And don't forget to give the truck a good shove to try ot knock it off the stands. If it won't come off the stands, it's safe.
