oil pan
big_blue_72
oil pan
Post by big_blue_72 »
i have a 72 short bed i am swapping a 6cyl over to a 87 H.O. 302 can i use the rear sump pan or do i have to change over to a front sump and will i have to change my motor mount towers :?
wt4speed#2
re: oil pan
Post by wt4speed#2 »
Hey Good luck
I'm doing about the same swap ,except with an unidentified BB , the towers for I-6 and fe motors are the same, but the 302's are not interchangeable , the engine stands for the 302's are out there and you might look at several before find a set that haven't been cut on
As for the oil pan my motor was out of a supercharged '85 stang kid bought it for the supercharger and scraped the bulk of it ,I end up with what turns out to be a '87 truck block 302 but it has the mustang pan I think either will work
The block is bored .30 over, roller lifters and rockers , heads turned out to be "66" series289 heads ported and polished intake and exhaust ,domed cylinders and stainless intake valves
Keith put to get a tech page on the engine stands when i posed this question
Tony B
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
