brake clutch
- customcrewcab
brake clutch
well got the brake and clutch worked out. also welded up the big whole where the steering comes out. you can also see the metal that was added to the inner fender to cover where the steering box was. with the 3/8 plated the hydroboost worked perfect with the pedals.
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
re: brake clutch
what exactly are those 4 top bolts for stock? I loosened them and nothing fell haha so I am guessing they are just there?
- MadMaxetc
hey, can you post a pic of how you did your clutch? I am going to be doing the same thing soon.
Thanks,
Thanks,
Dan
Project: '63 F-100 LWB / 460 / C6 / 2x4 / Work In Progress!
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
"Work Harder! Millions On Welfare Depend On YOU!!"
FORD Girl
Photobucket Pictures
FORD Girl
- customcrewcab
re: brake clutch
well i guess theres 6 because it helps hold the dash and the steering is tied in. MadMaxetc are you talking about the clutch cable? i tied it into the 3/8" bracket because there is alot of presure on the firewall. inside i just took the existing and added another piece to the help clock the alumimum part. here is a pic.
- customcrewcab
re: brake clutch
almost forgot i had to remove the brace under the dash that comes down in a angle because it hit. i guess i could have trimed it but is seems just as sturdy.
- MadMaxetc
Thanks for the pictures. did you check to make sure that you get full clutch disengagement? Our trcuks have a longer arm and more travel than a car. I am just wondering about ratios.
Dan
FORD Girl
FORD Girl
- customcrewcab
re: brake clutch
well i am running a t-56 and am not 100% sure. should be ok. i have adjustment on both the firewall and the clutch cable where it hooks in the arm. i still need to move or build a new transmission crossmember. i am waiting until i get it to my buddies shop and it on the lift. its alot heavier then the t-5.
re: brake clutch
well yah, there are 6 on yours, but stock the two that bolt to the master cylinder arent connected in any way to the upper 4. and i removed the top 4 and nothing happened. MAybe I am missing something. Looks good though, I want to run one of these somehow.
re: brake clutch
Those 2 extra holes are to connect the brake booster if your truck is so equipped.
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
