alittle...progress
zakt
alittle...progress
Post by zakt »
got a front axle to roll the truck around, and getting close to welding up all the rear holes from the old leaf hangers. Also, getting ready to set the front up with brake lines and mounts from my 85' F350 (80-97 F350 brake lines are the same).
Todd
1972 Ford F350 crewcab
Heavenlyfire
re: alittle...progress
Post by Heavenlyfire »
Right on, love progress :thup: . Keep us posted
mrsnicks
Post by mrsnicks »
Nice.
I still covet/envy your jack stands.... Don't you need bigger/better/badder ones so I can have your old, wornout, used ones?
Patrick
Chevrolet
Can Hear Every Valve Rattle on Long Extended Trips
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
http://www.fordification.com/galleries/ ... ?cat=10336
wt4speed#2
Post by wt4speed#2 »
Religion is not the strongest of my strong suites. But I'm almost certain the commandment that says"Tho shall not covet another man's....." includes his jackstands.A couple of "Hail" Henry Fords ought to do it
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
RebelRider
Post by RebelRider »
Those jackstands are awesome. They could probably hold up those gals in the "Rate this tailgate" thread! :D
Torque....God's gift to tire dealers!
Dave
Image Image
http://www.fordification.com/galleries/ ... ?cat=10571
GT-Racer
Re: re: alittle...progress
Post by GT-Racer »
RebelRider wrote:Those jackstands are awesome. They could probably hold up those gals in the "Rate this tailgate" thread! :D
That Ain't right..... :wf:
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
MadMaxetc
Post by MadMaxetc »
:doh:
Dan
Project: '63 F-100 LWB / 460 / C6 / 2x4 / Work In Progress!
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
"Work Harder! Millions On Welfare Depend On YOU!!"
FORD Girl
Photobucket Pictures
rjewkes
Post by rjewkes »
where do you get jackstands like that? are they designed for deisel rigs?
fuelly.com
wt4speed#2
Yea big trucks and 4x4s, We used them for frame stands, and basically that's what they are designed for . We also had shorter stand that looked simular to what many of us have in our garage only rated at higher weights ratings
Tony B.Image
DFW Area
"Someday...
Member#'s 236 & 403
wt's ride
thebucket
zakt
Post by zakt »
Those bad boys are rated 10tons and I believe go like 46" high, I will have to max them out and see what the height is :D. Looks like you can no longer get these specific ones though. Once I get the 12-14" lift on and the 40" tires I will need something tall to get it off the ground without using the axles.
http://www.jackxchange.com/products/W93525.cfm
rjewkes
Post by rjewkes »
pretty pennies only need apply for them. Maybe i'll find a used pair in realy good condition.
fuelly.com
ezernut9mm
Post by ezernut9mm »
looks like progress to me zakt. keep the pics comming.
wanting to buy a mercury tailgate!
"the man who is swimming against the stream knows the strength of it".- woodrow wilson
