does anyone still make the molded heater hoses that got from the factory Air box in the cab thru the firewall?
Any suggestions for a work around if they are still not made?
thanks.
bob.
Factory Air in cab heater hose 71'
- frisky
71 f100sb 390/edelbrock everything, 66 F100sb 240ci, 36 flathead pickup, 30 A roadster, Cat D2, Basset Hound Tucker.
re: Factory Air in cab heater hose 71'
Hmmm...I'm not sure I know what hoses you're referring to.
The only molded hoses that I'm aware of on these truck are the radiator hoses. The heater hoses that go from the engine to the heater box inside the cab aren't molded...that hose is sold by the foot at any parts store.
Last edited by FORDification on Wed Mar 30, 2005 12:52 am, edited 1 time in total.
- frisky
these are two hoses, that run from the core tubes and make a 90d turn to go thru the firewall, where they meet the regular engine compartment heater hose (regular by the foot roll stock)
These molded hoses are about a foot long, have a wiggle or two in them and then the 90 turn, regular hose would not make the turn thru the firewall.
- 4x4x4crewcab
Do you have a system like this?
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
1999 Ford Windstar
- 4x4x4crewcab
If what I am reading is correct. There was at one time available from Ford
a couple of preformed hoses---described in catalog as follows
F100/350--with integral a/c preformed 5/8 I.D. X 46.00" long
C8TZ.18472.A
and
F100/350--with integral a/c preformed 5/8 I.D. X 25.50" long
C8TZ.18472.B
I am pretty sure this is what your asking about. By the length they must have went all the way to the engine originally.
these have long been discontinued from Ford but maybe somebody like NAPA etc.. can cross the numbers for you?
C8TZ.18472.A
and
C8TZ.18472.B
Mark
1999 Ford Windstar
1999 Ford Windstar
- frisky
Yes, thats it!
The hoses when I got the truck, where spliced to regular heater hose at the engine side of the firewall using two 3" lengths of some steel tube and 4 hose clamps.
The two ideas I have had were to use some wire wound hose like used in aircraft, or to solder some soft copper tube onto the heater core and bring that thru the firewall.
Wow.
I don't think I'd solder that long of a tube to the heater core, as it would probably fatige from vibration, but if you are handy with a pipe bender I don't see why you could not form a couple of copper lines and attache them with short rubber hose tot he heater core.
- 4x4x4crewcab
I would get the hoses out and take them into a few larger dealerships. Ford, Chevy anybody with a large inventory. There can be numerious hoses,tubes etc.. a guy can make work or get by with. Its worth a try just hope you find someone that is willing to take a few extra minutes to help.
Mark
1999 Ford Windstar
1999 Ford Windstar
